Page 1 of 1
[ 4 posts ] |
Alternator or Voltage Regulator?
Author |
Dennis
Joined: March 24th, 2009, 9:18 pm Posts: 248 Location: 15340 Mourjou France
I'd been away for a fortnight's holiday (leaving the Red Special behind) and when I got back it was reluctant to start - and it's usually absolutely immediate.
Then last night coming back from dinner with friends I thought the headlights looked dim. This morning it wouldn't start: no click from the solenoid at all. I jump started with another battery, but after that the voltage reading at the battery was a steady 10v (!). We were very lucky to get home last night it seems.....
I am currently - hah! - charging the battery. That should tell me if it's a battery problem.
How can I tell whether it's the alternator not delivering anything, or a failed voltage regulator?
If it is the voltage regulator, I'll be a bit miffed, as it is the expensive solid-state version, only about two years old, and never maltreated. After all, it's been working fine up to now.
Where do I test, and how? Suggestions welcome.
_________________ Dennis usually in the Cantal
1964 HY 72 (Type H, campervan) - LHD 1969 AZU 250 (formerly French Post Office van) - LHD 1982 Red Special - RHD 1983 Burgundy/Black Charleston - RHD 2017 Skoda Octavia Estate 1.4 DSG - LHD
August 22nd, 2021, 12:03 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2247 Location: Near Monmouth
 Re: Alternator or Voltage Regulator?
My 2volts…
Requires a multimeter to see voltage. Temp hook up a 12 volt lamp to alternator Exc spade connector and the battery 12 volt. Start the car measure the volts on the battery, if over 12 volts Alternator is functioning.
Or
Borrow a regulator to swap with yours.
Solidstate regulators are reliable for many years .
Cheers Peter
August 22nd, 2021, 5:04 pm |
Dennis
Peter: thanks.
Starting to check I think has shown me what the problem is. The "exc" lead on the alternator was very loose and showing signs of sparking/burning. Actually at first it was rigid, but as soon as i moved it, it became wobbly. It had maybe corroded into a set position that didn't conduct well.
I have cleaned it up and tried (not very successfully) to tighten up the connector - it's inside a fairly rigid plastic cover and not easy to bend into a more grippy shape.
With the car running I now have 14.5V at the battery, as against 13.4V when the engine is turned off.
Should I maybe think of clipping the end of the lead off and putting on a new female connector? There's not a lot of slack in the cable, though.
August 22nd, 2021, 6:35 pm |
Ianredspecial
Joined: June 22nd, 2014, 8:09 pm Posts: 1293 Location: Reading, Berks UK
I vote for new connector. But how annoying to have to extend the wire somewhat for such a short distance.
August 22nd, 2021, 9:16 pm |
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: No registered users and 53 guests |
