We have liftoff.....AZU 250 rebuild thread http://www.international2cvfriends.com/forum/viewtopic.php?f=7&t=6302 |
Page 18 of 19 |
Author: | Geert [ February 24th, 2021, 6:58 pm ] |
Post subject: | Re: We have liftoff.....AZU 250 rebuild thread |
"szép " as they say here. |
Author: | 48pop [ April 17th, 2021, 11:19 pm ] |
Been a while ! So.....Noticed a wee spot of oil when parked up, on a normally "dryish" engine. With visions of crankshaft oil seals, oil cooler unions etc. I removed the fan and rubber shield.....odd, all looks fine and dry. A brief wipe around with a cloth and degreaser and I put it all back together....As my nose was level with the coil I spotted the source of the oil spotting.....the COIL, dripping from the middle joint. Not seen that before...Replaced with a spare and all is well. Also managed to get my "clacker" indicator switch back in, no more misindications........ Also spotted the holed crossbox.... |
Author: | 48pop [ June 19th, 2021, 12:39 pm ] |
If anyone is looking at this thread, you will know that the van has a nice, shiny Chassis on it now. I held on to the old one with the intention of fixing it up and storing .......(goodness knows why....) Top and bottom plates perforated and some of the stiffeners on top and bottom flanges. Anyway, took the grinder to it yesterday, its not too bad photo host Nice and clean...ish at the back Some weldy, weldy to happen, then clean, paint, wax |
Author: | subarupete [ June 19th, 2021, 5:46 pm ] |
Repair, refurbish, reuse, gets my vote |
Author: | AZL57 [ June 20th, 2021, 10:12 pm ] |
Nice job, i seen worse exemples saved. |
Author: | 48pop [ June 27th, 2021, 12:13 am ] |
welding day...... Wainting on some fluids before putting base and floor plates..... |
Author: | Geert [ June 27th, 2021, 7:14 am ] |
Good job ! |
Author: | AZL57 [ June 27th, 2021, 1:16 pm ] |
A friend did waxoil his chassis and the started to weld..... boom a plier that was laying on the chassis was stuck in the ceiling.... |
Author: | subarupete [ June 27th, 2021, 1:23 pm ] |
Was grinding with a battery “on charge” at the other end of the bench... bang....battery with the top off .....acid on the bench, now very careful when welding, grinding etc... |
Page 18 of 19 | All times are UTC + 1 hour [ DST ] |
