We have liftoff.....AZU 250 rebuild thread http://www.international2cvfriends.com/forum/viewtopic.php?f=7&t=6302 |
Page 15 of 19 |
Author: | subarupete [ September 28th, 2020, 7:09 pm ] |
Post subject: | Re: We have liftoff.....AZU 250 rebuild thread |
Great bit of fabrication work. |
Author: | Roger V [ September 28th, 2020, 7:42 pm ] |
Its amazing what you can do with a hula hoop! Love it. |
Author: | 48pop [ September 28th, 2020, 7:58 pm ] |
Due to tight confines of the adapter, i needed to buy some M7 allen head bolts........12 quid for 5 !!! Damn you Citroen and your M7 fetish ! |
Author: | Roger V [ September 28th, 2020, 8:19 pm ] |
I drilled and tapped to M8 |
Author: | 48pop [ October 4th, 2020, 11:28 pm ] |
OK, doing a bit of a dash swap today, simple and now MPH...... I find I have a few spaces, I've seen blanks for the wee round holes, are blanks available for the rectangular holes ?? Also, I need a working wiper switch...anyone have these bits for sale? Swap was very awkward and fiddly....... Mostly working and I now have an oil warning light......and, no front lights.....Will get it finished over next week ! |
Author: | Geert [ October 5th, 2020, 9:41 am ] |
Ask Roger V if he can print these blanks . He owns a 3D printer as I understand |
Author: | AZL57 [ October 5th, 2020, 11:08 am ] |
The little lights you can take out of the other dash they are the same. Dash is normally fixed with this type of lense shape screws. |
Author: | Roger V [ October 5th, 2020, 11:42 am ] |
I moved my hazard switch to the left side. The two holes at the top I use for left and right indicators. The wiper switch stayed in the bottom right corner. However, in the square hole above it, i have repurposed the brake fluid test bulb button to operate the electric windscreen washer pump. |
Author: | Ianredspecial [ October 6th, 2020, 12:16 am ] |
Electric washer pump?? Poshe. |
Author: | 48pop [ October 7th, 2020, 2:45 pm ] |
OK, confused....... As above, I've swapped the dash. Car starts and runs, I have tail lights, indicator and horn.....I have no front lights, nothing, no sidelights, no dipped headlights and no full beam. I did have the lightswitch disconnected but I have checked and its all back as before. My meter says I have 12+ volts coming to switch and when I turn the knob, 12+ volts at all other terminals (except horn) Any thoughts on what I've missed before I tear it all out again.....? (I had lights before the swap) |
Page 15 of 19 | All times are UTC + 1 hour [ DST ] |
