View unanswered posts | View active topics It is currently September 24th, 2019, 10:44 am
Reply to topic  [ 9 posts ]
 Breakdown
Post Breakdown
Hi all is there anyone in the Falmouth area could help with a breakdown? Failed ignition I believe.
Thank you.
March 19th, 2019, 11:10 am
Post Re: Breakdown
Graham Wilson at Callington is the nearest specialist, still about 60 miles from Falmouth, though...
tel. 07773 625 124
https://www.ecas2cvparts.co.uk/info_pag ... 60255b8503
Thank you.
March 19th, 2019, 11:25 am
Post Re: Breakdown
I'm in exeter
Do you know what you actually need?
March 19th, 2019, 12:17 pm
Post Re: Breakdown
Thanks Ken I'll pass the number on.
Thanks Roger, its a pal of mine I sold the car to a few years ago, seems the 123 has died. He has a points ignition set at home near Plymouth and has now got a lift back there to get the bits so he can fix tomorrow. He has not done ignition swap before but is reasonably mechanical soo should manage.
Thank you for responding.
March 19th, 2019, 2:42 pm
Post Re: Breakdown
You may like to suggest he check the voltage output by the alternator, as a high voltage can damage electronics. If it is high, check all the connections including ground, before buying a replacement. :D
March 19th, 2019, 3:15 pm
Post Re: Breakdown
Don't forget the box spanner to get the fan blades off with - is it 14MM (someone please check). I always carry that one with me.
March 20th, 2019, 9:02 am
Post Re: Breakdown
yes it's 14 mm.
March 20th, 2019, 9:09 am
Post Re: Breakdown
Thanks all, he's still stuck in Falmouth (kipping @ a mates I believe) and now seems to have killed the nice new dry coil...
March 21st, 2019, 2:52 pm
Post Re: Breakdown
Does sound like over voltage!
Where is he based when not stranded?
Edit
Ok, re read topic and its near Plymouth. :D
March 21st, 2019, 6:59 pm
