View unanswered posts | View active topics It is currently April 23rd, 2024, 11:40 am
Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
 68 Dyane boot handle
Post Re: 68 Dyane boot handle
Derek wrote:
That's odd - can't see my images now. Is it me, or are they gone for everyone?
It's not just you Derek. I can't see them either
November 20th, 2018, 7:39 pm
Right! Seems TinyPic are back up - let's have another go -
The inner barrel, right, can suffer from corrosion built up within the handle which will cause issues with fatigue when truning the key. It is that barrel which is in pieces with Ians problem.
Don't forget to replace the circlip (almost out of shot at top), otherwise you will find the barrel with the tumblers coming out with the key!
The sprung plunger if not lubricared can cause the small spring to break, or simply seize up with crud, resulting in a lock that will not unlock, or not lock.
November 21st, 2018, 9:52 am
