Page 1 of 1
[ 3 posts ] |
Author |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1581 Location: Exeter, Devon
Alternator Noise
Hi all Alternator is making a noise, but if I remove the exciter wire, the noise stops! Is this normal? Cheers
May 9th, 2017, 7:00 pm |
Derek
Re: Alternator Noise
Removing the exciter lead will cause a loss of demand, therefore the alternator will be under no load. When under load, it is likely to produce a sort of moan, which will alternate when the Voltage Control Regulator cuts the alternator in and out.
Unless the noise is that of a worn bearing. Depends on what sort of noise you are hearing.
May 9th, 2017, 9:28 pm |
Roger V
Thanks Derek Moaning is a good description.. So that would appear normal then. As I have a spare that needs attention, I may recondition one of them and see if that helps. I have so much noise and vibration from the engine/gearbox that I will keep picking at it and replacing/reconditioning parts. Thanks again
May 9th, 2017, 11:15 pm |
Page 1 of 1
[ 3 posts ] |
Users browsing this forum: No registered users and 74 guests |
