All about: 2CV suspension
http://www.international2cvfriends.com/forum/viewtopic.php?f=7&t=485
Page 5 of 25
Author:  Russell [ May 20th, 2010, 8:27 pm ]
Post subject:  Re: All about: 2CV suspension
Jameswallace wrote:
its the bit you are looking down in this pic
http://photos-h.ak.fbcdn.net/hphotos-ak ... 9867_n.jpg
im not sure if im honest, its an 88 e reg, can you sugest where i get one from ?
is it an easy job to fit (im an ameteur!!) but i noticed the other day it had a hole in it, must of been like that for a while, i think its the one the spring sits in as aposed to the oil canasters??
may be wrong of course...
Right, the spring can, the big tube with the springs in, should have a fair bit of oil sloshing about in it, probably vegetable or caster. If the can's got a hole in, the oil will have leaked out, I assume? There are no seperate oil canisters.
ECAS sells replacement spring cans. http://www.ecas2cvparts.co.uk/spring-tu ... -1186.html
£20, Sorted! You'll need a 44mm spanner, a pair of axle stands, a grinder and a welder. Just remember the order everything comes out in, or better still, as you remove a part from one can, fit it into the other, making sure you mark which end is which.
Author:  J-dub [ May 20th, 2010, 8:42 pm ]
how urgently do i need to buy a new one, and is it an easy job to fit??
well the oil has never leaked out when i owned it.....
it must explain why the suspensions slightly higher on one side (in and half) i thought it was weight of battery or something..... (as the side battery is on is slightly lower)
also how long would it take to do, and is it something an 2cv ameteur like me can acheive... what sort of oil also?
Author:  toomany2cvs [ May 20th, 2010, 8:43 pm ]
Did you put any in there?
No, that's just adjustment of the tierods.
Can you weld?
Veg oil, not engine oil.
Author:  J-dub [ May 20th, 2010, 8:45 pm ]
i can weld just, but... as its a just ill get someone to do it, i never put any oil in it because i only bought itabout 2 months ago and must of been like this when i bought it, well how do i go about adjusting the ride higt on that side??
Author:  J-dub [ May 20th, 2010, 8:46 pm ]
also veg oil, my friend has tons and i mean tons of used vegatable oil, is used ok ? bit gloopier than new oil or does it have to be new oil?
Author:  hjbharry [ May 20th, 2010, 8:48 pm ]
Why not engine oil Adrian?
That's what i used :?
Author:  Luke [ May 20th, 2010, 8:50 pm ]
how big is the hole? If it's just a pinhole, you should be OK to just turn the can around so the hole's on the top, and put some oil in it. The can *should* turn relatively easily when the car is jacked up off both wheels on that side.
Obviously that's not a goer if the things full of holes and there's always one on the bottom! ;)
Author:  Joe [ May 20th, 2010, 8:51 pm ]
:lol:
Author:  J-dub [ May 20th, 2010, 8:52 pm ]
i wouldnt say a big hole bit it isnt small so ill go with a new one i think, and if its rusting its gunna go anyway....
Author:  Neil [ May 20th, 2010, 8:52 pm ]
It breaks the rubber down.
Have a look at this:
viewtopic.php?f=5&t=529&start=80
Page 5 of 25 All times are UTC + 1 hour [ DST ]
