View unanswered posts | View active topics It is currently May 2nd, 2026, 12:26 am
Reply to topic  [ 3 posts ]
 Suspension Revelation.
Post Suspension Revelation.
So... after some 4-5 years of owning and fidling with my 2CV I decided to check/adjust the suspension. The car was with new shocks and no suspension complains.
When I came to the adjustable end-pieces, either way of the pot, I found them 2-3 mm tighter than recommented, so they were adjusted the Haynes way.
Imagine my surprise when I test drive the car!!!
It became soft and supple and comfy as a true citroen should be.
Now I drive over bumps and holes and I hardly feel them.
Also the front-back oscillation was reduced together with the sudden "crashing" and the rear "bottoming".
I've Been Wrong Before.
September 4th, 2012, 11:17 am
Post Re: Suspension Revelation.
you can,t beat the original set up taskos! don,t forget to squirt some cooking oil into the cans(both ends)
September 4th, 2012, 6:54 pm
So I did.
Sunflower seed oil.
September 4th, 2012, 9:12 pm
Users browsing this forum: Google [Bot] and 134 guests
