View unanswered posts | View active topics It is currently May 6th, 2026, 11:44 am
Reply to topic  [ 3 posts ]
 carb/jet size query
Post carb/jet size query
hi fella,s-only meeee :? my 2cv (602 cc)D*lly, twin choke carb, normal engine ,electronic iggy , high output coil-
well, when i,m driving/pottering along ,using a very light foot on the throttle- the first carb barrel only used-- the engine is very hesitant, it "hunts", kind of pulls then not in rapid succession :? it seems like the fuel delivery is not even-
if i floor it and the second butterfly opens all good :D goes like a rocket( comparetivly :lol: }
ive been told that if i remove the brass secondary? primary? petrol jet in the carb,- then drill it out slightly bigger- that will cure the problem :roll:
my question is ,can i just purchase a modified one
btw ive stripped the carb and cleaned it thorough-ly
a modified jet, a modified jet-- my kingdom for a modified jet :D
July 5th, 2012, 1:01 am
Post Re: card/jet size query
No kingdom or king's ransom required... :roll:
http://www.ecas2cvparts.co.uk/primary-v ... -1454.html
July 5th, 2012, 1:21 am
Post Re: carb/jet size query
thanks so much ken :D top man --- smooooth runnnning -- i,ll get the correct one
cheers& thanks
July 5th, 2012, 2:35 am
Users browsing this forum: No registered users and 115 guests
