View unanswered posts | View active topics It is currently May 6th, 2026, 2:24 pm
 Solex 30 pics carb
Post Solex 30 pics carb
Hi,has anyone got a picture of this carb?It appears that the choke knock off spring is incorrect,as it will not do its job.I have tried it in various positions,but just can't get it to work.I can only think its the wrong spring,hence the picture.
Or even a carb for sale?
Dave.
January 31st, 2012, 10:02 am
Post Re: Solex 30 pics carb
Further down this page
viewtopic.php?f=7&t=3426
the forked lever should straddle the pin on the choke cam
as for the spring its been about 25* yrs since i played with one of those so im afraid spring location isnt something i could comment on.
January 31st, 2012, 11:17 am
:roll: I knew I should have mentioned that I just placed the carb top onto the float bowl before some smart arse noticed it :lol: :lol: :lol:
January 31st, 2012, 11:41 am
*15 yrs im not that old
and that spring doesn't look right the 2 legs appear to be bearing on 2 fixed points on the body - should be one leg locating on that pin the other on some part of the cam or linkage
they are not here yet ;)
January 31st, 2012, 11:42 am
Patience,they will be ;)
January 31st, 2012, 12:14 pm
city link .....im not holding my breath
January 31st, 2012, 12:26 pm
I think I may have sussed it.Will post pics when I get home :D .
January 31st, 2012, 7:29 pm
turned up at about 3
whats wrong with them? they are perfectly servicable some very light corrosion on one, more the coating blistering off than pitting - i could just polish them and say "erm - £30" :?
ill measure them make some template, clean them and send them back unless you really want copper ones :lol:
January 31st, 2012, 8:47 pm
No,they are the ones off my spare engine.The ones on my useable engine are fine after I cleaned them.You wanted some for a template,so now you have them :lol: .If you think they are OK,thats fine,I can arrange to get them collected when your finished with them,just let me know.
January 31st, 2012, 9:10 pm
Dave,
just in case, here's a reference photo for you.
A bracket on the fast idle cam comes into contact with the outer leg of the spring when the choke flap is 'about' two thirds closed.
Guess the idea was to prevent the driver from setting off with the choke closed, much the same setup was used on early versions of the 26/35 carburettor, until someone came up with the bright idea of the "choke pull-off device"... :roll:
Solex 34 PICS 6 Choke return spring by slcchassis, on Flickr
January 31st, 2012, 9:11 pm
Users browsing this forum: No registered users and 110 guests
