View unanswered posts | View active topics It is currently May 6th, 2026, 12:25 pm
Reply to topic  [ 6 posts ]
 no power to the coil
Post no power to the coil
So after a year of owning my new oil feed pipes, i finally fitted them today, what a pain in the ass....
so I re assembled everything, all went back together fine after lots of swearing and shouting, and I now have no power to the coil,
Ive traced backwards, I have power at the fueses, and the fuse is all fine, and I have power coming out of the ignition barrel, but from the fuse up to the coil is no power...!!
is there a splitter somewhere after the fuse? as its all on the same circuit that isnt working (ie not just the coil, the wipers and indicators dont work either)
IIRC There is one of those shocking citroen cable splitter thingys just after the fuses
now my real question is, being that its wipers and other things, is it split behind the dash to go to the wipers etc, or is it split on the bulkhead?
All was fine when i parked the car up 2 weeks ago, so wondering if the pixie's have been at it??
December 28th, 2011, 4:01 pm
Post Re: no power to the coil
James,
there are items which go 'live' and are fed via a fuse when the ignition is switched on, but the supply to the coil isn't one of them.
December 28th, 2011, 5:00 pm
Ok..
ive found the problem
after un wrapping the loom, testing everything and not finding any faults, turns out its the month old ignition switch i fitted
sigh :(
back to put the loom back in
December 28th, 2011, 5:01 pm
You sure everything from the points box to the coil is still connected? Seems a bit of a coincidence that you've taken it apart today and now it doesn't work.
December 28th, 2011, 5:10 pm
Its usually the bits that came apart when you did the last job in this case its likley to be the flying lead that goes down hrough the cowling to points and oil press switch or the big bundle for the lamp bar, cant see wht=y one of the hatd wired splices or the fuse box would need to be touched to get the oil lines
Edit oh sorted!
December 28th, 2011, 6:02 pm
By passing the ignition switch sorted it. I'll run with it like this for now.
I haven't touched the car for a few weeks!
December 28th, 2011, 6:05 pm
Users browsing this forum: No registered users and 133 guests
