View unanswered posts | View active topics It is currently May 6th, 2026, 12:26 pm
 RHD bulkhead panel
Post RHD bulkhead panel
As title, is such a thing available anywhere? Computer says no. I could probably do a bit of cutting and grafting of a LHD one, but would rather not..
Thanks
December 3rd, 2011, 1:26 pm
Post Re: RHD bulkhead panel
Not available,
however might be worth looking at George's 'cut and shuffle' of the LHD version?
viewtopic.php?f=5&t=1201&start=70
Thanks
December 3rd, 2011, 1:33 pm
Brilliant, I couldn't picture what the side-specific section looked like, but that looks easy peasy! Will do that. Thanks Ken.
December 3rd, 2011, 1:48 pm
Just make sure you 'measure twice, cut once', as it would be a pain to correct if it was slightly off. :)
Also a bit of copper or brass or something helps when welding it up again, because you have to bridge the width of the cutting discs with weld.
December 3rd, 2011, 5:08 pm
I thought the lower bulkhead was available?
December 3rd, 2011, 6:35 pm
Lower bulkhead is but that only includes the bottom triangular box section and they're all just flat panels with none of the original fluting or detail, the complete bulkhead upto the join is available but only in lhd, doesn't take long to convert it though.
December 3rd, 2011, 8:05 pm
Ah ok
I thought cassis or spoof would of sorted or been on the case ;)
December 3rd, 2011, 8:46 pm
Nope, Cassis have none either. It looks very simple, will see how it goes. Might buy a few and convert them if anyone would be interested.
December 3rd, 2011, 9:00 pm
If this conversion does not work,
you could ask 2cvKeza to make a RHD bulkhead panel for you !
I am sure he would love to help you .
December 3rd, 2011, 10:45 pm
That's a good idea. 2cvkeza could make it in s slightly thicker material too ?
December 4th, 2011, 8:16 am
Users browsing this forum: No registered users and 127 guests
