1-2-spark
http://www.international2cvfriends.com/forum/viewtopic.php?f=7&t=3003
Page 87 of 88
Author:  aus602 [ August 5th, 2016, 1:26 pm ]
Post subject:  Re: 1-2-spark
Thanks Geo. Understand fully. We're thinking about what we might be able to do about this so enthusiasts can benefit whilst protecting your interests 100% so it can be developed even further if you feel like it.
If it was easy we'd already have an answer, so it might take a bit of time (plus whatever time it takes for 65 cars and interested parties to get back from raid 2016 australia, and start making sense).
Author:  subarupete [ August 7th, 2016, 11:44 am ]
Modern meets Old :D
Just brilliant.
Thanks Geo
Author:  lpgo [ July 18th, 2019, 9:35 pm ]
So a probably costumer wants to have coil on plugs in his 2cv and if I could realize this with 1-2-Spark.. So I wanted to now myself by ordered two pencil coils which are directtly mounted on top of the plug.. So no coil-leads are neccecary annymore so less can go wrong..
This evening I put a little testbench together and made the rpm raising from about 150rpm all the way up to around 9000rpm...
Creating a lot of ozon in my livingroom :D :D :D :D
so pump up the volume and watch the video...
https://www.youtube.com/watch?v=NdRgDT4 ... e=youtu.be
Author:  subarupete [ July 19th, 2019, 8:41 am ]
Like it.
Is it an "add-on" to the existing board or brand new PCB.
Perhaps use these
https://www.ebay.co.uk/itm/Ignition-Coi ... SwVQBdA1II
Author:  lpgo [ July 19th, 2019, 11:11 pm ]
No you csn use them insted of the 2cv coil. However you need probably another coil driver because you have 2 coils now. When I,m back from Croatia I will test it in my car.. your Jaguar coil is a good fing by the way..
I have the dwell time reduced to 1000 over the whole range..
Author:  Roger V [ July 20th, 2019, 11:32 am ]
I have some VAG smart COP for when I eventually get my speeduino installed. :roll:
Author:  lpgo [ August 20th, 2019, 11:04 pm ]
So tonight I had some spare time so I installed the coil on plugs in my Ami.
I just pluged them onto my plugs, no brackets yet and hey it works.. It feels like the engine runs slightly better/nicer with the new coils.. So I'm going to make 2 brackets this week and then have a test drive..
I guess I will never use coil-leads anymore...
Anyone seen a 2cv running without coil leads... take a look at the video..
https://youtu.be/41zNy0oRHbk
Tomorow I will put the car outside in the sun and make another video so that you have a better view..
Author:  rob massey55 [ August 20th, 2019, 11:55 pm ]
that's Witchcraft 8-)
Author:  lpgo [ August 21st, 2019, 6:23 am ]
Almost...
Author:  subarupete [ August 21st, 2019, 8:02 am ]
Brilliant,
Which COP units?
Any modifications to the 1-2-Spark control unit?
Page 87 of 88 All times are UTC + 1 hour [ DST ]
