View unanswered posts | View active topics It is currently February 22nd, 2026, 1:28 am
Reply to topic  [ 9 posts ]
 A spring that dont know where to put
Post A spring that dont know where to put
Guys yesterday i found a spring that looks like the one on the accelarator but it is shorter ( around 3cm-4cm).
I found it in the fan's housing and it looks dirty ( meaning it must be somewhere out).
Another thing that concerns me a lot is that i am hearing a tiking from the left side of the engine. The noise is not metalic and i was looking if there is a connectikon between the spring and the noise.
Please advice.
November 7th, 2011, 4:30 pm
Post Re: A spring that dont know where to put
is it a spring off your headlight adjustment rod? there should be 2 where the rod joins the headlight bar.
November 7th, 2011, 5:42 pm
Pavlos,
Would you say its more a "tapping" sound??
it could be the valve clearences
November 7th, 2011, 7:50 pm
there can be springs attached to the heating systems-valves, for heat or no heat when the spring is gone the valves can vibrate so make noise....
November 7th, 2011, 11:07 pm
I didn't knew that. in that case i am missing one more.
On the orher hand i don't remember noticing any spring during installation.
but if there isnt any spring around there then this has to be. the one.
I checked the valve clearance and it is ok.
November 7th, 2011, 11:24 pm
Valve clearances tend to 'tap' it's nothing to be concerned about tbh
November 8th, 2011, 12:53 am
ok guys i found the location of the springs and i bought a pair today.
I ll leave the rest trying to get the 2cv on the road as soon as possible . then i ll look that sound too.
November 8th, 2011, 4:24 pm
I got my valves adjust the way that is on the sticky . But after two adjustments (both exhaust and intake .25) i am still hearing this tapping sound.
A friend of mine told me that i don't have to worry cause the rods that are pushing the valves get smaller by the time so there is a tapping sound. But i think that this maybe not my problem cause if it were then i should listen this sound from both of the cylinders.
Is there any signs of not well adjustment valves when you are driving ?
December 3rd, 2011, 11:09 am
There should be a gap and there should be a noise when its working " a tappy tappet is a happy tappet" is a well known saying, the adjustable rocker arm is known in English as a "tappet" due to the sound it makes.
An aircooled engine is much more resonant due to the cooling fins and so will sound loud if you are used to water cooled engines with hydralic valve gear. It is most noisy when cold
If the engine gets so it wont start when its hot then that is a sign that the gap has closed and the valves are slightly open. The pushrods do not normally wear its when the valve head and its seat start to wear out that the gap closes.
other noises can be piston slap if the pistons are worn or fitted wrong and the "little ends" (english)- "wrist pin bushes" (US eng)
December 3rd, 2011, 11:30 am
Users browsing this forum: No registered users and 118 guests
