View unanswered posts | View active topics It is currently March 17th, 2026, 2:38 pm
Reply to topic  [ 198 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 20  Next
 Place for switches or gauges
Post Re: Place for switches or gauges
I have one in the shed somewhere! One of many un-planned projects.
October 4th, 2020, 10:08 pm
I bought the throtle body in the far East. In the meantime I fabricated a bar to hold the hall sensor for the crank rotations.
October 6th, 2020, 12:28 pm
Something that worked for me ....
Run the engine on the old carb and ignition, and test all your sensors are working to your satisfaction, before commiting to them. :)
October 6th, 2020, 9:49 pm
How does that bar bolt on, as can see from image?
October 6th, 2020, 9:50 pm
The plate with the sensor has two slots which slide over the connection rods for the bellhousing. The plate is pressed tight between the bellhousing and the engine casing. I use a Visa engine on a 2cv gearbox. They need a distance ring of 3 mm between the bellhousing and the engine casing. With the plate, (which is 2 mm thick) in place the distance ring has to be 1 mm. I also will put glue between the engine casing and the alu cable guide to prevent vibration of the sensor plate.
October 7th, 2020, 8:55 am
Whatever you can do to stop vibration, would be a good idea. :)
I printed my in abs, and am amazed it still works!
October 7th, 2020, 10:32 am
A 3D printer would be an excellent help for me too ! But now it will be too late since I have not many stuff to design.
October 7th, 2020, 12:09 pm
Injection system : what is good advise about the most suitable point to start the injecting of petrol in an 2CV engine ? Is it simultanious with the opening of the inlet valve or is it better just before the opening ? If I am well informed the opening of the inlet is a few degrees before TDC.
November 20th, 2020, 5:01 pm
Hey, how ya doin? :)
In the first instance, all you really want to do, is get some fuel in there. :)
2 squirts per cycle, simultanous will do it.
One squirt will put it somewhere around induction. The other squirt will put it on the back of the inlet valve. Both will end up in the cylinder when its needed. :D
November 20th, 2020, 8:01 pm
@Roger V : in order to be able to inject sequentially, I have fabricated a small bar (from an old curtain rail :lol: ) holding a magnet. It can turn inside the ignition box and gives one pulse per complete cycle of the engine. Possibly we will also receive an electronic solution from a Speeduino fan.
December 5th, 2020, 6:52 pm
