View unanswered posts | View active topics It is currently February 17th, 2020, 6:13 pm
Reply to topic  [ 10 posts ]
 volts
Online
Post volts
Morning all!
Battery is showing healthy readings with and without load with my avo meter but the car's volt meter reads just above the shaded area. Should I believe the car's meter? Is there a way to tweak it to give a more accurate reading?
I do tend to watch a car's dials so it's a little unnerving to see a low charge reading.
Thanks
February 10th, 2020, 11:46 am
Online
Post Re: volts
I've no experience with the volt gauge, only what I've read.
With a multimeter, what volts are you getting at the battery at about 1500 rpm?
February 10th, 2020, 2:24 pm
Online
Post Re: volts
Battery voltage is around 13.2v not connected: after starting on fast tickover it reads around 14v (I don't have a rev meter), but as the revs increase the reading is about 14.6v, Headlights on doesn't make a difference, so I don't think there seems to be a problem with the actual charging.
It's just I don't know whether the 2cv gauge is known for being particularly accurate.
February 10th, 2020, 11:25 pm
Post Re: volts
The car´s volt meter is not accurate.
My 2CV volt meter shows just above the shaded area .As yours does
I checked the voltage with a multimeter several times and that was fine .
It runs well, no problems starting, having lights on etc., even in frosty winter weather, so I would not be worried about it.
Ez a türelem kérdése.
February 11th, 2020, 9:34 am
Online
Post Re: volts
The 2cv voltmeter is an bimetal that is heated by a resistance cable wound around it so nothing accurate as Geeert says.
February 11th, 2020, 9:44 am
Online
Post Re: volts
I'm reassured : thanks to you all.
February 11th, 2020, 10:35 am
Online
Post Re: volts
I was trying to say much the same, but my IPaddress was blocked!
Edit
How about that, you leave it over night, and it fixes itself. :lol:
February 11th, 2020, 11:06 am
Post Re: volts
Please do not exceed 14,6 vollts
I've Been Wrong Before.
February 11th, 2020, 1:01 pm
Post Re: volts
Did you write anything nasty on social media ? :?
February 11th, 2020, 1:17 pm
Online
Post Re: volts
Not aware of any.
Think it was just a glitch, and an odd error coming up. :)
February 11th, 2020, 6:09 pm
Users browsing this forum: AZL57, Bing [Bot], indian46, Roger V and 23 guests
