World meeting 2019 http://www.international2cvfriends.com/forum/viewtopic.php?f=6&t=6149 |
Page 2 of 2 |
Author: | Roger V [ August 8th, 2018, 5:11 pm ] |
Post subject: | Re: World meeting 2019 |
Are you sure it is fully in 1st gear? What condition are the rubber grommets on the linkage? Under normal driving without the trailer, is 1st gear noisy at all? |
Author: | mobylette69 [ August 8th, 2018, 6:08 pm ] |
Yes linkages look fine..1st gear doesnt sound any noise than usual...Im not sure if there is a thrust bearing issue as there is whine or rattle when I engage clutch |
Author: | AZL57 [ August 8th, 2018, 8:06 pm ] |
Are the motor and gearbox support rubbers ok? |
Author: | mobylette69 [ August 8th, 2018, 8:25 pm ] |
They all look fine, in normal use it never has popped out of gear...maybe it just wasn't in correctly ?? |
Author: | EirikJ [ August 9th, 2018, 9:47 am ] |
Make sure the gearlever doesn't touch anything in the engine compartment when in 1st gear. Or any other gear for that matter.... |
Author: | AZL57 [ August 13th, 2018, 5:13 pm ] |
The edge of the fire wall is dented in the 2cv i don't know if that if the dyane is also. |
Author: | samfieldhouse [ August 22nd, 2018, 10:11 am ] |
AZL57 wrote: The edge of the fire wall is dented in the 2cv i don't know if that if the dyane is also. I thought that was only early 602s |
Page 2 of 2 | All times are UTC + 1 hour [ DST ] |
