Author |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1634 Location: Exeter, Devon
 Re: Yellow Dyane
Quote: I'll try and post more citroen stuff , but there might be some LandRover content lurking in the background  Feel free  I posted about a generator! My friend has a Freelander I need to fix
November 29th, 2023, 7:53 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2217 Location: South-Limburg
 Re: Yellow Dyane
To help you a bit my Minerva Licence Landrover...
November 29th, 2023, 8:02 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 877 Location: Rhayader Mid Wales
 Re: Yellow Dyane
I'm not suprised it fell over, they're only rated for 30 degree side slopes
November 29th, 2023, 8:06 pm |
Roger V
 Re: Yellow Dyane
Ahh! I see your problem ... You don't need to do that. You could of just drilled some holes in the floor to let the rain water out!
November 30th, 2023, 9:44 am |
AZL57
 Re: Yellow Dyane
Thanks for the info, never know that works too...  It would also have helped to put the handbrake on...
November 30th, 2023, 10:18 pm |
rob massey55
 Re: Yellow Dyane
P1030882 by Robndaisy, on Flickr Happy New Year folks, getting too much fresh air from these vents because the thin seals have long gone. P1030883 by Robndaisy, on Flickr P1030884 by Robndaisy, on Flickr P1030885 by Robndaisy, on Flickr Luckily Mike has put a technique in the club handbook, has anyone ever resealed these vents? Car is running very well and is my only vehicle as the landrover needs a bit more work  If you click on the pix it takes you to flickr where you can zoom in.
February 3rd, 2024, 2:04 pm |
AZL57
 Re: Yellow Dyane
We took the dash apart. First the top cover of and then qou can release the nuts of the vents under the bonnet and take them out. Remove the clips should release moving parts.
February 3rd, 2024, 7:12 pm |
rob massey55
 Re: Yellow Dyane
I remember putting a lot of copper grease on the bolts and nuts so getting them out should be ok, I should have done the seals when I was re-installing. The heater is pretty good and demists much better than the 2cv.
February 3rd, 2024, 8:47 pm |
rob massey55
 Re: Yellow Dyane
Daras Rich sells the seals as a kit https://retrospecparts.com/
February 4th, 2024, 10:56 am |
rob massey55
 Re: Yellow Dyane
I finally got round to sorting out the vents. P1030891 by Robndaisy, on Flickr The kit I bought from Daras at Retrospec has good instructions for fitting news seals without splitting the casings. He warned that it's fiddly. I decided to split them. Drilled and prised out the rivets. P1030898 by Robndaisy, on Flickr P1030897 by Robndaisy, on Flickr The louvres are held in by a pin with a nut and a pin with a spring clip. there are nylon washers each end. P1030896 by Robndaisy, on Flickr P1030892 by Robndaisy, on Flickr Cleaned everthing and fitted the new seals, they're self adhesive and fitted really well. I used M4 bolts instead of rivets to hold the two halves together. P1030903 by Robndaisy, on Flickr P1030901 by Robndaisy, on Flickr The units are bolted to the firewall with five square headed bolts held in the plastic moulding. One bit of the moulding had broken so I brazed the bolt to a stip and anchored it to the side of the casing. I refitted both of them and now I don't have to wear gloves when driving  Other news, had a major oil leak from the oil pressure switch, found a spare in my stash and it seems to have cureds it. Bought a spare. Was reluctant to start from cold, removed coil and ht leads , cleaned and waxed them, now it bursts into life whatever the weather and we have had a lot of rain. Today it is glorious but I don't trust it to hold. The car is my daily driver and I'm finally pleased with it. The heater is much better than the 2cv, no so many draughts either
March 31st, 2024, 12:02 pm |
Users browsing this forum: No registered users and 31 guests |
