My Beduino
http://www.international2cvfriends.com/forum/viewtopic.php?f=5&t=6044
Page 27 of 29
Author:  Roger V [ September 25th, 2020, 9:42 am ]
Post subject:  Re: My Beduino
So, i tried it yesterday on my way to shop, and the cap came off the water reservoir, and dumped all the water. :D
So, designed a new cap for the reservoir.
The return line is in the cap. The addition of the inner collar, should stop the cap popping off whilst under load from the return pipe.
Author:  subarupete [ September 25th, 2020, 12:23 pm ]
Your 3D printer was a solution waiting for problems.
Keep up the good work
Author:  lpgo [ September 25th, 2020, 5:15 pm ]
Hilarious..
Author:  Roger V [ September 26th, 2020, 11:06 pm ]
Trying to get the temperature up on the reducer as much as possible, so added some jubilee clips to the copper coil in the exhaust. Clamped one end, and turned the coil to tighten it against the exhaust pipe, and clamped other end with the clip.
The clamps will also stop the coil chattering against the exhaust pipe. :)
Author:  Roger V [ November 6th, 2020, 7:52 pm ]
I have the Shed running in LPG. :D
However, I'm trying to add another sensor to the firmware, and its doing my nuts in! :( :cry:
Author:  AZL57 [ November 7th, 2020, 8:30 pm ]
It's autumn you should have nuts around this time of year... ;-)
Author:  Roger V [ November 7th, 2020, 11:07 pm ]
@azl57
Plenty of nuts about, but i have get it done before i go back to the institution, as they are not much help!
Author:  Roger V [ November 8th, 2020, 10:19 am ]
Fuel Temp Sensor added to software. woo woo :D
Now to move the Inlet Air Temperature sensor as its getting heat sink with the Dyane airbox being over the exhaust.
Its been starting on lpg now as well, after a few cranks. Still needs tweaking though.
Once it starts reliably on lpg, i will see about adding the fuel pump to the petrol side. :)
Author:  Roger V [ November 11th, 2020, 6:46 pm ]
Moved iat sensor to rubber connector between air filter box and carb. Much more sensible readings at idle now.
I think where the sensor was mounted on the filter box, stopped air passing it at low rpm. But that part of the box was being heated by the exhaust, causing heat soak to the sensor. That in turn caused the ECU to pull fuel and weaken the mixture.
Needs a run and log to confirm. And probably retune. :)
Author:  Edce [ November 11th, 2020, 8:49 pm ]
Quite an improvement I am sure !!!
Page 27 of 29 All times are UTC + 1 hour [ DST ]
