Author |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2009 Location: South-Limburg
Re: AZL 1957
Yep the AZ(Luxe) the luxe was 2 horns, aluminium trim on bonnet and door sills, and on the doors.... very luxe... And an wider rear window i thought.
April 23rd, 2019, 10:31 pm |
AZL57
Re: AZL 1957
Here another 2cv i cut out off a bramblebush in 1988. Geo knows it too. it was later put in an barn but i don't know if it's still there...
May 8th, 2019, 9:51 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1094 Location: Magyarország
Re: AZL 1957
Mind the bonnet !
May 9th, 2019, 7:36 am |
AZL57
Re: AZL 1957
it's rather solid if you stay near the hinge...
May 9th, 2019, 5:12 pm |
AZL57
Re: AZL 1957
Some bastard parked into my grille and took off.
June 6th, 2019, 4:44 pm |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 870 Location: Rhayader Mid Wales
Re: AZL 1957
That's bad luck but, because it's metal, you can carefully fix it, unlike the modern plastic sh*t.
June 6th, 2019, 6:13 pm |
AZL57
Re: AZL 1957
After i took the inside mesh off, i could push it back and to do a bit of work with the undenting set. Some paint flaked off and two half chevrons broke their fixing lugs...
June 6th, 2019, 8:22 pm |
AZL57
Re: AZL 1957
The dent is flattend but the bonnet seems to be tordated. One side scratches on the wing the other side i can put an hand between.... Here the repaired chevron halves, with new lugs glued on with 2K.
June 7th, 2019, 8:53 pm |
AZL57
Re: AZL 1957
Did take the lot apart again yesterday. Slightly bend the bonnet in diverse directions, take an wing off, loosened the bumper and moved that a bit forward. Bend the bonnet catch. Put everything back together and no more scratching sounds while driving. pff. Still to do put one broken twice chevron-half back in, than the wire mesh and the aluminium grille surround. And if have to get some paint to retouch the grille.
June 10th, 2019, 9:00 pm |
EirikJ
Re: AZL 1957
Thanks for making this nice thread.
Personally I avoid parking places where the cars are standing in a line. Because I think of other drivers like raving lunatics with no skills in car handling.
I prefer those parking spots where the cars stand parallel to each others. I believe the chance of getting away from that unharmed is better.
June 11th, 2019, 7:40 am |
Users browsing this forum: No registered users and 82 guests |
