say hello to "Arfur" the azu.
http://www.international2cvfriends.com/forum/viewtopic.php?f=5&t=5068
Page 8 of 9
Author:  J-dub [ January 9th, 2014, 7:53 pm ]
Post subject:  Re: say hello to "Arfur" the azu.
So how come you can hand crank a car with a dead battery
Author:  knightley [ January 9th, 2014, 9:02 pm ]
Because the 'dead' battery may just have enough juice to power the ignition system. If it is totally flat then you don't stand a chance.
Very old cars and motorbikes had magnetos which generate the electricity for the spark. You can start them without a battery.
Author:  samfieldhouse [ January 9th, 2014, 10:47 pm ]
In My experience you need at least 8v in there to have any luck. With a DEAD battery reading nothing on a multimeter) even rolling down a steep hill over about 100m won't get you anywhere.
Author:  lpgo [ January 9th, 2014, 10:54 pm ]
You can make a 2cv run on a 9 volt battery (little rectangle block battery) I once did that on points, will work with my ignition too I'm pretty sure, however don't hit the brakes/lights or its gone....
and you need to take the connection of the dynamo of.... (I guess but I didn't remember doing that.)
Author:  samfieldhouse [ January 9th, 2014, 11:48 pm ]
That's pretty cool 8-)
Author:  Tripyrenees [ January 10th, 2014, 9:41 am ]
Exactly - I rolled down 10 km at an average of 7% in 3rd gear trying to start and there was nothing.
Only a boost from a 12volt booster got me home in stages.
But now I have fixed my dynamo there is no stopping me :)
Author:  sig [ January 11th, 2014, 7:10 pm ]
thanks for that guys, I tried it with a battery but still no joy, probably the plugs, and all the earths need shining up. anyway the blokes pickup has arrived so i´ll have to be working on that for the next month or so..the thing is massive you could get the azu on the back of it!!
Author:  Jacqueslemac [ January 11th, 2014, 7:48 pm ]
Get rid of that plastic chair and it could be a calendar shot!
Author:  sig [ January 20th, 2014, 7:55 pm ]
thanks jacques ;)
pleased with my find today
pulled out some very slick seats with headrests from a dyane in the scrap yard today.
the pair along with a set of seats for a mercedes fintail, and a mercedes headlight for 100€
bargain
Author:  sig [ January 25th, 2014, 5:47 pm ]
guess who´s a happy bunny !!!!
ME ! :D :D :D
arfur is alive.. the new old starter motor arrived today, and after a bit of messing around with cables and dodgy earths it started spinning on the 12 v battery. than after reminding myself of geos advice for starting sidney, I did the same thinng with the cable from the distributor to the coil, and sparks started to happen.
then with help from my daughter and a couple of tubes it started cranking up. now it sucks from the bottle and stays alive really well.
I let it run for a while to warm up and have just changed the oil now also.
no exhaust on it so sounds like a tractor but frankly even then it sounds smooth and solid
vid to follow
happy !
Page 8 of 9 All times are UTC + 1 hour [ DST ]
