View unanswered posts | View active topics It is currently April 26th, 2024, 7:39 am
Reply to topic  [ 91 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
 1965 2CV AZ
Post Re: �1965 2CV AZ
My son made some parts himself ˝just for fun ˝:
And with some newly bought replacement parts it all comes nicely together :
April 7th, 2023, 6:32 pm
April 7th, 2023, 6:45 pm
My AZ dates from june 1965, so it could be issued with 3 side windows, or with 2 on each side.
This one has original 3 side windows, but we decided to convert it to 2.
Now i have a question.
The place of indicator on the side near the rear door differs in these two cases.
What i need to know is where the indicator should be located when the car only has two side windows .
Could someone please measure the distance from the rearside of the B pillar , and the distance from the bottom of the sill, or bottom rear wing to the central hole where the indicator is positioned ?
Many thanks in advance
December 23rd, 2023, 1:47 pm
Hi Geert same position as the earlier cars. I can measure that for you. Maybe this pictures will help too?
https://2cvgarage.nl/aanbod/2cv-az-2/
December 23rd, 2023, 11:58 pm
That would be great if you could do that.
I have photo' s of older cars, but not the exact position of the indicator . I can' t measure it from a photo.
Many thanks !
December 24th, 2023, 9:51 am
Dag Geert, The middle hole is 34cm up from the innerwing and 10cm (horizontaly) from the rear door frame. Both measured from the inside. Diameter 1 cm.
December 25th, 2023, 2:30 pm
Thank you ! Great help !
Have a good and peaceful Christmas !
December 25th, 2023, 4:51 pm
Thanks, you too.
December 25th, 2023, 10:27 pm
Before spraying the body, we put it together for the test. Now we come across a small problem.
How is that little clamp on the back of the rear mudguards fixed ? We tried to fix it,but we can't get it fixed properly .
March 5th, 2024, 8:12 am
It normally is hammered on from the bottom. Think of fitting the aluminum lining between wing and body first.
Here an interesting catalogue for you with also the later 18HP models
http://jplerouge.free.fr/2cv/2cv%201949-68.pdf
March 5th, 2024, 11:43 am
Users browsing this forum: No registered users and 151 guests
