1955 Traction Avant 11cv http://www.international2cvfriends.com/forum/viewtopic.php?f=5&t=4619 |
Page 38 of 43 |
Author: | lpgo [ March 17th, 2015, 10:58 pm ] |
Post subject: | Re: 1955 Traction Avant 11cv |
are you going to be a gangsta now??? (over here in Holland they were called gangster cars)... tractions are famous, it is very normal that you pump the brakes twice befor it starts to brake.. I'm with Ken and Fer... (First try Ken) |
Author: | Geert [ March 18th, 2015, 8:52 am ] |
As I bled the brakes of my AZU, after restoration, it took ages before the pedal was hard . With every new attempt there came more bubbles . I almost gave up , but at last everything went well. Give it some time ! |
Author: | Tripyrenees [ March 18th, 2015, 1:57 pm ] |
I went and bought an Eezibleed kit as the one we had seems to have disappeared Put it on as the instructions (20PSI off my Dyane spare ) and the fluid rushes into the Master Cylinder. Went to the rear right brake drum, opened the bleed nipple expecting it to gush out (I have used this kit before on my son's mini) but just a slight trickle. This cannot be right. So off comes the NEW master cylinder and I open it up to compare to the old one. I did measure the plunger orifice too and the new one is 44mm long and the old one is 46mm so not sure if that could make any difference But when I opened up the new I had a few too many parts floating around in side. The little non return valve had unriveted itself and the spring and holed disk were just rattling in the chamber. Hence the pedal going solid and no liquid able to exit the master cylinder. Not too happy but I have my old (new replacement non return) part from the old Master Cylinder that I will put in now and try. |
Author: | Tripyrenees [ March 18th, 2015, 6:38 pm ] |
VINNY IS BACK ON THE ROAD 1st time on the road since 1970 (just been told by the last owner who we stopped by the house and tooted, hello!) Took him over the petrol station and put in 30 litres and up comes 30 litres on the fuel gauge...so that works. Lots more work to do to get him tidy but for now, he is a running Traction again https://youtu.be/Ucsp6PdzF7A Here is the previous owner taking a look - all the family came out, joking how many babies were made int he back..... note to self, clean thoroughly Parked outside his new home. |
Author: | Geert [ March 18th, 2015, 6:51 pm ] |
YEEEAAAHHH ! |
Author: | Jonathan [ March 18th, 2015, 7:26 pm ] |
Nice. I'm jealous. I want one. |
Author: | Tripyrenees [ March 18th, 2015, 7:57 pm ] |
No stopping me now https://youtu.be/dHVlGwMDvtc |
Author: | Chris2cv [ March 18th, 2015, 8:49 pm ] |
Utterly fantastic, Trip. You must be absolutely chuffed to bits. Having done a similar ground up restoration on a couple of old Brit bikes over the years, I know the feeling of satisfaction you must be getting driving around in a vehicle in which you know every nut and bolt.......and what they do. Well done! |
Author: | Tripyrenees [ March 18th, 2015, 8:51 pm ] |
I am chuffed My wife, Julie, commented as we pulled up the small rise over the river "wow, it actually pulls up hill, not like the 2CV" It drives very nice - trouble is that I am listening out for everything to see if anything is going wrong. A van came from the other way and past us and flipped up some plastic rubbish from the road that hit the front of the car - straight away I pulled over thinking I had dropped the engine or the wheel had fallen off. I will be like this for a while I think - never built a car or engine from scratch before |
Author: | AZL57 [ March 18th, 2015, 10:32 pm ] |
well done... |
Page 38 of 43 | All times are UTC + 1 hour [ DST ] |
