1976 AZU250
http://www.international2cvfriends.com/forum/viewtopic.php?f=5&t=3554
Page 37 of 42
Author:  Geert [ May 26th, 2015, 6:57 am ]
Post subject:  Re: 1976 AZU250
Smiffy wrote:
Calling all metal gurus!
Does anyone on here have the metal bending skills/equipment to fabricate one or two of these (one for each side of the vehicle) for me?
Any luck with the metal edge ?
Never seen such a felt seal, I can't remember it was on mine .
Are you sure it is for 2CV ?
Over here they sell it like this :
http://www.treffpunkt-citron.de/2CV--Dy ... 10mm-.html
Author:  AZL57 [ May 26th, 2015, 7:02 am ]
never seen that felt seal too, are you sure it's a 2cv part?
Author:  Russell [ May 26th, 2015, 7:09 am ]
That felt part is on every spring can Ive ever taken to bits, definitely a 2cv part. Why it doesn't fit, I can't tell you. I suspect it's either a tighter fit than you're expecting or the new can end is made differently, but I doubt it's the latter.
I keep forgetting to take your drawing to work, but I'll try and remember today.
Author:  ken [ May 26th, 2015, 10:29 am ]
The pattern canister end is wrong, so another one to add to the list of poor quality replacement parts. :(
Author:  Smiffy [ May 27th, 2015, 4:58 pm ]
Rats! What's the best way out of this mess?? Return to Roy, or adapt the part?
Author:  Tripyrenees [ May 27th, 2015, 5:48 pm ]
Part not fit for purpose - send it back. If you adapt then "Roy" will just keep sending out crap parts.
Author:  Geert [ May 27th, 2015, 9:08 pm ]
Agree !!
Author:  Smiffy [ July 19th, 2015, 9:21 pm ]
Here are two different sets of springs. The ones at extreme left and second-right are for a 250. The ones at second-left and extreme right are for a saloon.
Do the different springs give a different ride? Are van springs stiffer? Softer ride?
Author:  Geert [ July 19th, 2015, 9:33 pm ]
I.m.o. there is no difference !
There is only a differend size for front and back suspention .
Author:  ken [ July 20th, 2015, 12:52 pm ]
'According to the book', an AZU used saloon suspension components.
However, the wire diameter and number of active coils changed over the years, so you're looking at diferences connected with year of manufacture, rather than model.
The range of wire diameters listed for AZU front springs runs through 14.35mm, 14.8mm & 15.25mm... ;)
Could you measure the wire diameters of your springs, to see if they're different?
Page 37 of 42 All times are UTC + 1 hour [ DST ]
