1988 2cv D*lly bits and bobs http://www.international2cvfriends.com/forum/viewtopic.php?f=5&t=1754 |
Page 3 of 44 |
Author: | J-dub [ May 27th, 2010, 7:40 pm ] |
Post subject: | Re: 1988 2cv D*lly bits and bobs |
Little Louis wrote: Jameswallace wrote: i got fed up of wipers and was playing around with the wiring and pulled one wire off and wherever i turn them off they turn off and stay where they are, would rather park them properly though, will print that sheet off and investigate! your frame is foooked i think you will find, are the nuts on the wiper spindles undone? what do you mean my frame?? yes ive done the wipers now they are perfect ![]() |
Author: | Little Louis [ May 27th, 2010, 7:43 pm ] |
do the wipers always stop in the same place and wont return? |
Author: | Little Louis [ May 27th, 2010, 7:47 pm ] |
what i meant by the fame was the black part that its all mounted to mine bent where the spindles attach so it stopped and would not return but if you've fixed it without touching that then its not that ![]() |
Author: | J-dub [ May 27th, 2010, 7:48 pm ] |
basically dunno if i made it clear the wipers parked on the right hand side in the line of my vision when driving, which irritated me alot i got fed up of this after a while so tried adjusting the parking following the haynes manual, failed dismally twice, i was then testing what wire did what on the back to see if i could over ride it so that i could control whereever they stopped to my leisure, and by accident realised if you take the wire no the right off, its a wight wire, theres 3 wires to the switch on the ctrl panel, next to the hazard switch, then where ever you turn the wipers off they stop immediatly, im assuming this by passed the relay.... but im not an expert but it worked for the time being, and now that my wipers park on the left ive re connected that wire and now when i turn the wipers off theyll continue to there parking place if that makes sense... and i see what you mean now, no its not bent just bloody rusty and that plastic crap is flaking badly! may have to make one up out of stainless, would look rather good me thinks! |
Author: | Little Louis [ May 27th, 2010, 7:51 pm ] |
dont fix it if its not causing problems at the moment its more trouble than its worth ![]() |
Author: | J-dub [ May 27th, 2010, 8:03 pm ] |
well its done whats done is done as they say!!! wipers are on left now ![]() will upload a picture in a minute hope im not boring everyone with my pictures etc just thought id let everyone know what im doing to give my ideas / take advice ![]() |
Author: | J-dub [ May 27th, 2010, 8:53 pm ] |
todays work done!! here ia my front matt i decided to make it look nice, used a bit of shoe polish and a shoe brush (hard brisltes) ![]() my wipers are now over to the left as you can see ![]() i wasnt happy after pulling the masking tape away as where i had left the masking tape on for 10 mins or so it had bled through the tape, so i re taped up again and did it again ![]() ![]() done now ![]() ![]() ![]() ![]() ![]() ![]() todays jobs done ![]() hope i havent boored you and thanks for all your advice look forward to your comments positive or negative ![]() |
Author: | Joe [ May 27th, 2010, 8:55 pm ] |
nice work! not boring at all, these threads that show progress are the best! just look at old nails bamboo thread. |
Author: | J-dub [ May 27th, 2010, 8:58 pm ] |
i hope they arent!! yes saw that ![]() well i will have a few more of these to come, as i do other bits and bobs, should of done it when i replaced the fuel line, the fuel line was absolutly perished to hell!!! glad you enjoyed following my day ![]() |
Author: | Jonathan [ May 27th, 2010, 9:02 pm ] |
James, how old are you? Are you driving yet, or are you prepping your car for when you get your licence? |
Page 3 of 44 | All times are UTC + 1 hour [ DST ] |
