Author |
Ianredspecial
Joined: June 22nd, 2014, 8:09 pm Posts: 1180 Location: Reading, Berks UK
Re: AZL 1957
It really is isn't it. I've been in lots of traffic jams in Kent because its summer. All the cars baking in the heat with their windows open. (Air conditioning is absolutely necessary in modern cars but doesn't work forever before needing work) and my with my front roof flapped open very comfy and also getting a nice tan. Its so good.
August 5th, 2022, 9:24 am |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2009 Location: South-Limburg
Re: AZL 1957
I was thinking of my only idle well running ivory 57. Could it be that there is a hole between in and outlet? ??
August 11th, 2022, 4:50 pm |
AZL57
Re: AZL 1957
I did put in an other manifold en yes the car revs up again. But it has a bit of trouble to reach top revs. So i think i have to adjust the ignition a bit.
August 20th, 2022, 2:48 pm |
AZL57
Re: AZL 1957
Was at an oldtimermeeting in germany today. Several interesting cars turned up.
September 11th, 2022, 5:38 pm |
Ianredspecial
Re: AZL 1957
Is car OK now?
September 11th, 2022, 6:59 pm |
AZL57
Re: AZL 1957
I was with the green 57. The other is revving up now but i still have to look at the ignition.
September 11th, 2022, 11:05 pm |
AZL57
Re: AZL 1957
I was checking the tyre pressure of the caravan and as the 2cv was parked next to it i checked that too. All tyres had lost about 0.4 bar. After pumping them up the car was 10km/H faster than before... )
September 23rd, 2022, 10:18 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1581 Location: Exeter, Devon
Re: AZL 1957
What do you set them to? I will have to google to convert to psi though
September 24th, 2022, 8:45 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 481 Location: Korpilahti, Finland
Re: AZL 1957
14,5 psi is 1,0 bar. If you needed the calculation ratio...
Same experience was, when temperatures got lower, on my Landy the 2,0 bar at 25'C was only 1,1 bar at 7'C. Well, much bigger air space on 245/75-16 than 125-15 or 125-16...
September 24th, 2022, 10:12 am |
AZL57
Re: AZL 1957
1.4 front and 1.8 rear. But on the sun visor is marked 1.0 front and 1.1 rear.. But that was for the Pilote tyres. I once drove a 2cv with pilote tyres, the suspension was even softer. We drove the cobblestones in Liege. You didn't feel anything... Only downside the softer tyres wore faster than the X-tyres.
September 24th, 2022, 10:49 am |
