subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2254 Location: Near Monmouth
 Re: Yellow Dyane
Skilled hero in my book.
| May 30th, 2020, 5:46 pm |
rob massey55
 Re: Yellow Dyane
P1030009 by Robndaisy, on Flickr This is what can happen when 'someone who should know better' uses an out of balance knot twist rotary wire brush without the guard. No cut (lucky for me) and the brush is in the bin. It ripped off the interior sound deadening/ sealer a treat mind  . P1030013 by Robndaisy, on Flickr Cutting through, leaving the original piece as something to weld to. P1030015 by Robndaisy, on Flickr Now that's out of the way it's easy to trim the outer remnants from the inside. P1030016 by Robndaisy, on Flickr Bolted onto the chassis and this is what you want to see, the toeboard panel sitting evenly across. seriously good panels Ken  . P1030020 by Robndaisy, on Flickr the outer panel, held off by the original pressings, will either flatten then or cut around them for final fixing. P1030021 by Robndaisy, on Flickr This repair panel fits well tidy. The front outrigger underneath will have to be replaced. P1030022 by Robndaisy, on Flickr The driver's side (nearside, right hand ) is along way from shore though  .
| May 31st, 2020, 7:36 pm |
rob massey55
 Re: Yellow Dyane
P1030036 by Robndaisy, on Flickr Finally was able to break out the welder and fasten the outer front sill repair that i'd made, permanently  . Tomorrow, the inner and maybe the front floor panel, maybe  . I'm so slow these days it's pathetic.
| June 12th, 2020, 8:48 pm |
rob massey55
 Re: Yellow Dyane
P1030039 by Robndaisy, on Flickr modified an axle stand to support the corner of the body while cutting around the the floor outrigger. Hung the door to check gaps ok. P1030042 by Robndaisy, on Flickr P1030044 by Robndaisy, on Flickr P1030045 by Robndaisy, on Flickr P1030047 by Robndaisy, on Flickr As far as I got, driver's side almost ready for welding in, and passenger side (which needs a lot of work) started. P1030046 by Robndaisy, on Flickr The trouble with Daisy being stuck in Portugal is that I have to make my own lunch these days  .
| June 13th, 2020, 7:21 pm |
subarupete
 Re: Yellow Dyane
Doorsteps look delicious
| June 13th, 2020, 7:47 pm |
Roger V
 Re: Yellow Dyane
Coming along nicely  Better than my painting.  You got any mustard?
| June 13th, 2020, 11:12 pm |
rob massey55
 Re: Yellow Dyane
P1030053 by Robndaisy, on Flickr That's the inner piece of the triangular toeboard being welded in thank flame! welding to decent steel like this is a pleasure, welding to the Citroen 'bean can' steel is usually fizzy but sometimes ok. This is when a Bedouin appeals, 'cos any offcuts could go into the woodstove
| June 28th, 2020, 7:16 pm |
Roger V
 Re: Yellow Dyane
The way I feel about the Shed sometimes, the whole Bedouin could go in the woodstove.
| June 28th, 2020, 9:04 pm |
rob massey55
 Re: Yellow Dyane
P1030064 by Robndaisy, on Flickr The floors going in, driver's side done, just doing passenger's. Back on the windscreen surround tomorrow,  . When bodyshell is flipped, I'll be able to finish closing off the ends of the sills etc. glad that's done, eventually  . Like me, you're probably sick of looking at it
| July 3rd, 2020, 6:20 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1203 Location: Magyarország
 Re: Yellow Dyane
This dyane in your hands makes me think of this song : https://youtu.be/IQNBQI3UDag
| July 3rd, 2020, 7:13 pm |
Users browsing this forum: No registered users and 167 guests |
