Author |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1577 Location: Exeter, Devon
Re: AZL 1957
Its been to cold to ride my bike to the farm. Apparently, it was very icy in the lanes this morning.
February 3rd, 2019, 10:27 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 1994 Location: South-Limburg
Re: AZL 1957
Ran into this picture of my car on the french Peugeot 505 site????
February 4th, 2019, 11:38 pm |
Roger V
Re: AZL 1957
That's nice What is the big wheel in the background?
February 4th, 2019, 11:45 pm |
AZL57
Re: AZL 1957
It's a part from a huge compressor from a zinc factory if i am correct. It is at the Zinkhutterhof Museum in Stolberg (D).
February 5th, 2019, 9:04 am |
AZL57
Re: AZL 1957
It's off the cliff. New old gearbox is smooth in all gears. But i only tried on the garage inner court. The front brakes aren't working good enough but that might be solved using them a bit. One handbrake adjusting screw doesn't go far enough. Biggest problem the headlamps don't work. The previous owner made some adjustements at the wiringloom. There aren't any connectors anymore in the front part... Have to take that apart to find the problem...
February 9th, 2019, 4:29 pm |
lpgo
Joined: November 8th, 2009, 5:42 pm Posts: 2846 Location: NL
Re: AZL 1957
AZL57 wrote: It's off the cliff. New old gearbox is smooth in all gears. But i only tried on the garage inner court. The front brakes aren't working good enough but that might be solved using them a bit. One handbrake adjusting screw doesn't go far enough. Biggest problem the headlamps don't work. The previous owner made some adjustements at the wiringloom. There aren't any connectors anymore in the front part... Have to take that apart to find the problem... Great news sofar.. Put an extra nut under the handbrake screw.. Bleed the brakes again fix the lights and of you go..
February 9th, 2019, 4:58 pm |
AZL57
Re: AZL 1957
Brakes have been bled 2 times, pedal is firm. I think the shoes have to form a bit to the shape the other drums. Clutch and centrifugal clutch work well. Both the gear boxes didn't have the eccentric adjuster nuts at the bottom of the shoes?? Strange.
February 9th, 2019, 6:08 pm |
AZL57
Re: AZL 1957
Well it's back on the road. I drove it home and started to unravel the wire loom to the headlamps the previous owner made. Under all tape and wrapping there submerged 3 plugs. That of the sidelights came loose. The 2 others the wires came out of the plugs, the previousowner did forget to pinch them in. So there is light now and it runs rather well and a lot more silent than before. I think the mounting with exhaust kit did help.
February 16th, 2019, 5:40 pm |
lpgo
Re: AZL 1957
Finally some great news.. Great to here that the gearbox works well.. I hope that You,re also OK again..
February 16th, 2019, 8:50 pm |
AZL57
Re: AZL 1957
Yes all ok now, thanks again. Only handbrake needs some more adjusting. In the wrapped wires i even found the wire for the second horn...it's an AZL AZ-luxe... Have to dig out an horn in my parts stock.
February 16th, 2019, 11:18 pm |
