Author |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 1993 Location: South-Limburg
Re: Spring is here but let's talk heaters!
A piece of plywood at the inside of the grille works nice too. We once did a test in autumn with a thermometer in the tube at the right footwell. It showed 70 degrees. Not bad...but the grille cover is needed.
March 21st, 2019, 9:14 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 480 Location: Korpilahti, Finland
Some "tuning" of heating system..: https://www.2cv.fi/keskustelut/aihe/sah ... en/page/4/Scroll down, there is some photos about making heat exchangers more efficient. Funny language, google translator might help a little...
March 21st, 2019, 1:11 pm |
AZL57
like the turning cover on the fan...
March 21st, 2019, 6:00 pm |
samfieldhouse
Neoprene tubing and properly set up controls. Even when it’s been below 0 this winter it gets WAY too hot in my 2cv. Electric fans are a bodge, you have a 9 blades fan doing up to 6000rpm - what are you expecting a diddy electric blower to do? Get it set up properly!
March 22nd, 2019, 3:17 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2130 Location: Near Monmouth
@samfieldhouse Try driving a 2cv when -20Deg C, you don't need a fan!
March 22nd, 2019, 7:47 pm |
jasu
subarupete wrote: @samfieldhouse Try driving a 2cv when -20Deg C, you don't need a fan! Pete, you need, 2cv doesn't...
March 22nd, 2019, 9:55 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1577 Location: Exeter, Devon
I think I should probably re think cooling on the shed as its probably over cooling as it has a lot of ventilation at the front. Good for hot countries I guess ..... If I ever live in one
March 23rd, 2019, 12:00 am |
rob massey55
Joined: December 21st, 2014, 7:33 pm Posts: 866 Location: Rhayader Mid Wales
If you can wait down there long enough Roger, you might get your wish .
March 23rd, 2019, 12:21 am |
