Make Your Own ....2CV.... 4x4
http://www.international2cvfriends.com/forum/viewtopic.php?f=19&t=3279
Page 84 of 105
Author:  subarupete [ February 9th, 2018, 12:54 pm ]
Post subject:  Re: Make Your Own ....2CV.... 4x4
Discs now fitted and different brace (x2) allows drive shaft clearance.
Whoopee, only two oil leaks.
Need a copper washer under the sump nut.
And a seal?? for the splined prop shaft flange??
Author:  lpgo [ February 9th, 2018, 2:16 pm ]
Great job you did then...
Author:  jasu [ February 9th, 2018, 3:04 pm ]
On Land-Rover there is felt under the nut at flange. And many put also some sealing/glue to splines to avoid leaking...
Nicely done when there isn't any other leaks..!
Author:  subarupete [ February 9th, 2018, 3:51 pm ]
Thanks guys.
Author:  jasu [ February 9th, 2018, 4:05 pm ]
Part no 5 on that picture...
Author:  subarupete [ February 9th, 2018, 5:08 pm ]
Something like this...
Perhaps make it from felt or soft rubber?
Author:  subarupete [ February 15th, 2018, 5:15 pm ]
Fitted the centre bearing for the front prop shafts.
Shortened the first of two prop shafts, combination of suzuki/truimph-herald bits.
Author:  subarupete [ February 17th, 2018, 4:58 pm ]
The first on and even painted it...
Author:  subarupete [ February 22nd, 2018, 5:17 pm ]
Ooh clean floor!.
Fitted the front diff prop shafts, they fit but very tight near the gearbox about 10mm clearance.
Author:  lpgo [ February 22nd, 2018, 8:04 pm ]
Only 5 weeks to Morvan.... you should hurry....
Page 84 of 105 All times are UTC + 1 hour [ DST ]
