Author |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2021 Location: South-Limburg
Re: Transfer box.. A new version...
Nice job, we had an CNC at work. You could make a program and the machine did the work.
May 6th, 2024, 10:12 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2185 Location: Near Monmouth
CNC would be nice, Lottery win maybe:) Bit of welding , Part number stamped:) and a breather fitted. Attachment:
May 8th, 2024, 3:06 pm |
subarupete
Loverly and warm in the shed, so I turned up a bung to go the the clutch shaft hole. Attachment:
May 9th, 2024, 11:50 am |
AZL57
looks nice, as you have part numbers people can order them
May 9th, 2024, 12:06 pm |
subarupete
May 9th, 2024, 12:59 pm |
subarupete
Was all going quite well, making the oil seal/bearing plate. See photo, the rebate on the back, about 2mm of centre:(. Hopefully, I can get a larger OD seal and of set the hole to match the "Bodged" bit. Attachment:
May 10th, 2024, 2:49 pm |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 482 Location: Korpilahti, Finland
Oh, that mistake is too easy to do. Have learned again about milling, with my tiny Bernardo... Working area about 100mm x 300mm, ideal to make small parts ro RC cars and Helicopters. Maybe enough to make some 4x4 parts also...
May 10th, 2024, 4:25 pm |
AZL57
I have an Emco Unimat 3 for all kind of tinkering also clocks etc.
May 10th, 2024, 4:34 pm |
subarupete
Hi, Guys, Small is good, teaches you Patience:)
May 10th, 2024, 5:42 pm |
subarupete
To cheer myself up, I put the diff together and did a quick video. Weight is currently and 25Kg, when finished 26Kg with all bolts and support brackets etc. https://www.youtube.com/shorts/sBXIjgUM3Hw
May 10th, 2024, 5:45 pm |
Users browsing this forum: No registered users and 4 guests |
