Author |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2201 Location: Near Monmouth
Re: Transfer box.. A new version...
Re-make the plate to retain the bearing and hold the oil seal. Attachment:
May 3rd, 2024, 2:47 pm |
subarupete
Half-way done.. Attachment:
May 4th, 2024, 6:52 pm |
Roger V
Joined: March 21st, 2013, 12:04 am Posts: 1588 Location: Exeter, Devon
I didnt know you had a milling machine!
May 5th, 2024, 2:47 pm |
subarupete
Brilliant bit of kit, bit like a (negative) verison of a 3D printer:).
May 5th, 2024, 2:50 pm |
subarupete
Back plate progress, now attached with M7 csk bolts (all the way fron China) needed to clear the chain. Ordered the 10mm rear cover alu and a small bearing for the other end of the bottom shaft. Attachment:
May 5th, 2024, 2:55 pm |
Roger V
Quote: Brilliant bit of kit, bit like a (negative) verison of a 3D printer:). do you have a link please?
May 5th, 2024, 2:59 pm |
subarupete
Dont understand link? What I meant was..... With a mill you remove vast amount of material, with a 3D printer you only add
May 5th, 2024, 3:08 pm |
subarupete
May 5th, 2024, 5:40 pm |
AZL57
Joined: October 22nd, 2014, 10:59 pm Posts: 2035 Location: South-Limburg
Is your mill CNC?
May 5th, 2024, 10:53 pm |
subarupete
Just manual (Myford -VMC-E)
May 6th, 2024, 8:19 am |
Users browsing this forum: No registered users and 4 guests |
