View unanswered posts | View active topics It is currently April 29th, 2026, 6:35 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 101, 102, 103, 104, 105  Next
 Make Your Own ....2CV.... 4x4
Post Re: �Make Your Own ....2CV.... 4x4
Engine and Diff Out of car.
Leak from 2 places as far I can find at the moment.
The Drive flange leaks :(.
I think I took of a "few" thou to many in the lathe should be 50mm but is less than that 49.75, luckily an imperial size seal may do the job 1.983" / 49.22mm.
The blanking plate also leaks :( will seal with some not so cheap "Devcon" aluminuim putty.
November 2nd, 2020, 5:44 pm
Re-Worked Drive Flange.
When the body is off the chassis, everything is accessible, now I need very long arms to fit the Prop-shaft bolts.
(The bloke that designed this? needs sacking.)
Fabricated a retaining ring,(with Loctite!) in place of nyloc nuts.
November 5th, 2020, 1:48 pm
Loctite is your friend :D
November 5th, 2020, 10:15 pm
https://m.facebook.com/story.php?story_ ... _group_cta
Pete
Always wondered what you were upgrading for, and then I was mentioned here ...
November 7th, 2020, 10:08 am
Spectacular...mine is 1/4 scale design :D
November 7th, 2020, 10:52 am
With 1/10 HP!
November 7th, 2020, 7:40 pm
Made a new seal holder and bearing plate, this will fix??? leak from the drive flange.
New item on the right.
November 9th, 2020, 5:11 pm
The other leak may be more serious, it leaks from my bearing end cover(like a core plug) the gearbox has no oil pressure, but oil will always find a way out.
Have used some Aluminuim Expoxy Putty. Will refill gearbox and pray....
The dark circle was weeping oil:(
November 9th, 2020, 5:21 pm
Fixed the oil seal leak by making a new cover, and a larger new seal.
Also used Expoxy Aluminium Putty on the core plug.
Filled box with fill oil and left overnight, no leaks.
I’m pretty sure the drive flange won’t leak, but when the box and oil get hot that will test the putty!
November 13th, 2020, 4:13 pm
Online
Fingers crossed.
November 14th, 2020, 7:46 am
