View unanswered posts | View active topics It is currently April 20th, 2024, 1:54 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 92, 93, 94, 95, 96, 97, 98 ... 105  Next
 Make Your Own ....2CV.... 4x4
Wiring in the Car.
Wiring under the Bonnet.
Wiring ToDo Basics.
Headlamps, Side, Indicators, Horn.
New Battery +VE and connections to main loom.
Extras bits +++.
July 16th, 2019, 1:23 pm
Fuel Tank Fitted.
Base is bolted to the floor and to the inner wing.
July 23rd, 2019, 5:48 pm
New main gearbox lever and try out for the Transfer box lever, new mount to be fabricated.
Revised shift pattern
Transfer box end of gear lever.
August 19th, 2019, 3:21 pm
Gear Lever (Scratch Head Moment's)
Transfer box new lever.
Now vertical, needs sanding and paint.
Lever End.
Mount for the lever and linkage that doesn't interfere with the seats or the seat rails
August 20th, 2019, 3:15 pm
Transfer box Lever.
Mounted to the same bit of chassis as the rear gear box support.
Need the nuts to be recessed as the foul the lever a bit.
Both ends now connected and it allows selection!
August 21st, 2019, 5:16 pm
Transfer Box new knob
Revised pattern due to the linkage used,
Final Mounting (famous last words)
Slot cut out to clear seat frame.
August 22nd, 2019, 3:34 pm
I.m still not sure which way round..
Design follows function or function follows design...
Hmmmmm...
Well the result is looking awsome.. (at least in my eyes).
August 22nd, 2019, 4:46 pm
Thanks Geo,
Hope to test it on the road (track) soon.
Need to fix the LDS pump/pipes/wiring for the suspension so it has some damping, at the moment the rear is like a Kangaroo.
Had is running a number of times, vibrates as the engine mounts are (through)bolted, when I carefully engage the clutch, more vibration from the extra shaft :( , gave it lots of revs and it has stayed together :)
August 22nd, 2019, 5:56 pm
Tight fit for gear lever.
Support for LDS tank.
August 29th, 2019, 6:04 pm
Well it's not like you'll be racing through the gears :)
Loving this build 8-)
August 29th, 2019, 6:45 pm
