View unanswered posts | View active topics It is currently April 25th, 2024, 1:50 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 68, 69, 70, 71, 72, 73, 74 ... 105  Next
 Make Your Own ....2CV.... 4x4
Thanks for the info guys,
The reason I am looking at a lower ratio is that I have 155/80 R15 tyres, and with the LNA gearbox it is really to long.
AlthoughI will be fitting the Visa engine some time... For slower climbing I think the lower ratio will be much better.
So practically, if i did get a custom crownwheel and pinion made, how difficult would it be to install in the gearbox?
It has been a while since I had the gearbox apart...
Cheers
February 16th, 2017, 11:34 pm
The most Precise job on an A series....
Setting the Pinion "Height" and Pinion "backlash".
Needs a dial gauge and some shims.
Rick Pembro, Gearbox Guru is the expert.
February 17th, 2017, 9:55 am
Milling the Back Plate.
https://www.youtube.com/watch?v=qJK-YUT04rY
February 21st, 2017, 5:08 pm
Great work Pete,
I used to mill stuff, we had an indexing head a bit like this https://www.google.co.uk/search?q=milli ... 9ksyDjE1DM: we used it to make PTO splined shafts for horticultural compost mixers. You could make your own gears when you've got five minutes :D
February 21st, 2017, 7:30 pm
@rob massey55, thanks also that is interesting, as I can borrow an indexing head from the guys that wire erode the internal splines. The next project is to mill splines onto a shaft....so I may pick-up some hints from you :)
February 21st, 2017, 7:40 pm
Looking forward to seeing that!
February 22nd, 2017, 12:28 am
Acquired some Coil Over springs, will fit these over the front struts, to provide, the standard ride height.
The plan being to use the LDS struts only when needed, thus the need for auto leveling should not be needed :D
Newish Springs
February 22nd, 2017, 6:14 pm
Got the loan:) of some Large tyres.
Well it now looks the part.
February 26th, 2017, 4:17 pm
Maximum and Minimum
February 28th, 2017, 6:01 pm
Needs lowering... :twisted: 8-) :mrgreen:
February 28th, 2017, 11:02 pm
Users browsing this forum: No registered users and 78 guests
